SKILL file for Path and bus creation
Subhash
Newbie level 6
Bangalore, Karnataka, India
virtuoso skill draw path
Hi Guys,
Need your help. I want to draw the Bus (metal paths) in Virtuoso Layout editor.
It takes more time for creation of a path and copy paste adjusting etc... etc...
Hence I am trying to write a code for creation of bus, for that i need to understand how the leHiCreatePath() function works.
Anyone who knows how the leHICreatePath internally works.!!!?
Or if any has already done the skill code for Bus creation please do let m e know.
Will look forward for your valuable reply.
Thanks and regards,
Subbu
erikl
Super Moderator
Staff member
Germany
ledefinempptemplate
Subbu
Hi Subbu,
perhaps you can get info about this topic in this group, especially from this thread.
Good luck! erikl
Reactions: Tprasad
    Subhash
    Tprasad
Teddy
Advanced Member level 1
skill code bus
I would not use leHiCreate... I would say for you the easiest way is to use multi part path mpp
For example 20um wide metal bus:
;The template name is : M5_Bus_20u,
leDefineMPPTemplate(
?techId tech
?name "M5_Bus_20um"
?layer list("METAL5" "drawing")
?width 20.000000
?choppable nil
?endType "flush"
?beginExt 0.000000
?endExt 0.000000
?justification "center"
?offset 0.000000
?offsetSubPath list(
list(
?width 20.000000
?choppable t
?sep 22.000000
?beginOffset 0.000000
?endOffset 0.000000
?subRect list(
list(
?width 4.000000
?length 4.000000
?choppable t
?sep 11.000000
?space 4.000000
?beginOffset -5.000000
?endOffset -5.000000
?beginSegOffset 20.000000
?endSegOffset 20.000000
?gap "distribute"
) ; end of leDefineMPPTemplate procedure
You can define it by text file like this or by clicking it in layout editor in Create - Multipart Path
    Subhash
Subhash
Newbie level 6
skillfile
Thank you very much Erik.
Hey the discussion u mentioned talks about changing the layer in leHiCreatePath and about changing the layer using replay files.
it was very informative but unfortunately I couldnt get much help for my goal.
If u find any other info please do let us know.
Regards,
Subbu
erikl said:
Subbu
Hi Subbu,
Good luck! erikl
Added after 4 minutes:
Hi Teddy,
Thank you very much for your reply.
At present we are creating the bus by this way.
It has few drawbacks like,
- If we want to stretch one single path in this path we will not be able to do so.
- if we want to vary the width/ space then we need to edit the subpart which I feel is a tedious job.
So we are trying to implement the easier way.
Regards,
Subbu
?techId tech
?name "M5_Bus_20um"
?width 20.000000
?choppable nil
?endType "flush"
?beginExt 0.000000
?endExt 0.000000
?offset 0.000000
list(
?width 20.000000
?choppable t
?sep 22.000000
?endOffset 0.000000
?subRect list(
list(
?width 4.000000
?length 4.000000
?choppable t
?sep 11.000000
?space 4.000000
?gap "distribute"
erikl
Super Moderator
Staff member
Germany
skill code to draw bus in the layout
offers skill tools for practical manipulation of bus routing.
Tprasad
Newbie level 5
Hyderabad
Re: skill code bus
Hai all
I know the code for creating MultiPartpath using SKILL code..........
but i don't know, how to utilize it while writing a code...
If anybody know this, please do let me know,,
Thank U
regards,
T.Prasad
erikl
Super Moderator
Staff member
Germany
Re: skill code bus
  • Write your code into a file, named e.g. fileName
  • In the CIW type: load("fileName")
  • If necessary, you can assign a bindKey to the load statement
Tprasad
Newbie level 5
Hyderabad
Re: skill code bus
Hai erikl,
How to create Blind Keys to select a particular layer in LSW , while designing layouts
If u know, please do let me know,,
Thank U
Regards,
T.Prasad
erikl
Super Moderator
Staff member
Germany
Re: skill code bus
BindKey (not: BlindKey !) definitions may depend on the C@dence version you are using, which you didn't mention yet. In version 5.1.41 you could write e.g. for activation by the key "b" :
hiSetBindKey("Layout" "<Key>b" "load(\"fileName\")")
You can write this definition into the CIW (every session), or put it into your bindkey file to be loaded automatically. Its name and location also depends on the version. For more info, better ask in one of the groups I linked to above.
Tprasad
Newbie level 5
Hyderabad
Thank You erikl
Now i am using Virtuoso 6.1.4 version
During creation of a Pcell, how can i use multi Partpath SKILL code for creating guard ring........?
Thank U
T.Prasad
---------- Post added at 14:21 ---------- Previous post was at 14:16 ----------
Hai erikl,
why we are using both multipliers and fingers for a transistor(MOSFET) during designing
What is the difference between multipliers and fingers????
Which one is use full.........?
Thank You
Regards
T.Prasad
erikl
Super Moderator
Staff member
Germany
I've got no experience with Virtuoso 6.1.4, sorry! Pls. search or ask in the appropriate !
Both: Multipliers are for a corresponding number of identical single transistors, whereas finger is for one single transistor with <finger_count> of gate fingers.
Tprasad
Newbie level 5
Hyderabad
Re: ledefinempptemplate
Hi erikl,
I want to draw inductor using cadence virtuoso 6.1.4 version. what are the different parameters we have, for an inductor??
Tprasad
Newbie level 5
Hyderabad
Thank You erikl,
I have a small doubt...
I saw transistors parameter defined as w=1u, l=2.5u, m/nf=4/5 and total M=20
what is the meaning of m/nf?
Is it dividing the width 5 times and repeating it 4 times....?
According to your replied yesterday, is it 4 identical transistors...?
Thank You
Regards
T.Prasad
G Sarath
Newbie level 1
Re: virtuoso skill draw path
Hi guys,
Can we us any no of fingers is there any disadvantages while using large no of fingers.If there is no limit to no of fingers why we are using multiplier.
erikl
Super Moderator
Staff member
Germany
If total M=20 I'd think this means 4 identical transistors with 5 fingers of w=1u, l=2.5u each. wtotal = 20µ .
---------- Post added at 09:44 ---------- Previous post was at 09:38 ----------
If you need matching of transistors (current mirrors, differential stages), you should make a symmetrical (common centroid) layout, which could mean a mix of several identical transistors. That's why you need the multiplier.
