sahu
Advanced Member level 2
- Joined
- Oct 9, 2009
- Messages
- 516
- Helped
- 68
- Reputation
- 130
- Reaction score
- 62
- Trophy points
- 1,308
- Location
- Uttar pradesh (INDIA)
- Activity points
- 3,876
help me this code ... for conversion
i am using PIC16F676 in place of PIC18F2620
found error .
#define IR TRISA.F3
#define LED1 PORTC.F0
#define LED2 PORTC.F1
#define LED3 PORTC.F2
#define LED4 PORTC.F3
#define LED5 PORTC.F4
#define LED6 PORTC.F5
#define BZR PORTA.F0
#define LED7 PORTA.F1
#define LED8 PORTA.F2
unsigned counter = 0;
unsigned input_data, bit_count;
enum {
Idle,
Start_bit,
Capture_bit
char Current_state = Idle;
char got_data = 0;
char Command_code, Device_code;
void interrupt(){
if(INTCON.INTF){
switch (Current_state){
case Idle:
[COLOR=#ff0000]INTCON2.INTEDG0[/COLOR] = 1; //interrupt on rising edge.
counter = 0;
Current_state = Start_bit;
break;
//found the rising edge, check lenght for 2.4ms
case Start_bit:
//correct signal, move on to next state
if(counter == 4) {
counter = 0;
bit_count = 0;
input_data = 0;
Current_state = Capture_bit;
} else {
//fault signal, reset to Idle
break;
case Capture_bit:
//check plus length for 0 or 1
if(counter == 2){
input_data >>= 1; // add 0 to received data
bit_count++;
}else {
if(counter == 3){
input_data >>= 1;
input_data |= 0x8000; //add 1 to received data
bit_count++;
} else {
//error occurs, reset to Idle state
[COLOR=#ff0000]INTCON2.INTEDG0[/COLOR] = 0; //interrupt on falling edge.
//compleat 12 bit
if(bit_count >= 12){
got_data = 1;
input_data >>= 4;
counter = 0;
break;
default: Current_state = Idle;
INTCON.INTF = 0; //clear interrupt flag.
if(PIR1.TMR1IF){
counter++;
if(counter > 5) {
counter = 0;
PIR1.TMR1IF = 0; //clear interrupt flag
// MAIN MAIN MAIN MAIN
void main() {
TRISC = 0; //portc is output
TRISA = 8; //portA is output
// RB0 interrupt set up
INTCON.[COLOR=#ff0000]INT0IE[/COLOR] = 1; //enable RB0 interrupt.
IR = 1; //RB0 = input.
ADCON1 = 0x0F; //all digital I/O
// Timer2 interrupt set up, interrupt every 600us
[COLOR=#ff0000]T2CON[/COLOR] = 2; //timer off, prescaler 1:16
[COLOR=#ff0000]PR2[/COLOR] = 149; //preload timer2 comparator value.
[COLOR=#ff0000]TMR2[/COLOR] = 0; //reset value timer2
PIR1.TMR1IF = 0; //clear interrupt flag.
PIE1.TMR1IE = 1; //enable timer2 interrupt.
[COLOR=#ff0000]IPR1.TMR1IP[/COLOR] = 1; //timer2 interrupt high priority
// Global interrupt enable
INTCON.PEIE = 1; //enable interrupt
INTCON.GIE = 1; //enable global interrupt
[COLOR=#ff0000]T2CON.TMR2ON[/COLOR] = 1; //timer2 is on
while(1){
if(got_data){
Command_code = input_data & 0x7F;
Device_code = input_data >> 7;
got_data = 0;
if(Device_code == 1){
switch (Command_code){
case 1: LED1 = ~LED1; break;
case 2: LED2 = ~LED2; break;
case 3: LED3 = ~LED3; break;
case 4: LED4 = ~LED4; break;
case 5: LED5 = ~LED5; break;
case 6: LED6 = ~LED6; break;
case 7: LED7 = ~LED7; break;
case 8: LED8 = ~LED7; break;
PIE1.[COLOR=#ff0000]TMR2IE[/COLOR] = 0; //disable timer2 interrupt.
Delay_ms(100);
PIE1.[COLOR=#ff0000]TMR2IE[/COLOR] = 1; //enable timer2 interrupt.
found error .
