sinrey
Junior Member level 1
SINREY SIP2703V network audio module is a general-purpose stand-alone SIP audio function module that can be easily embedded into OEM products. This module encodes and decodes SIP protocol and rtp audio stream from the network.
SIP2703V network audio module is used as a playback terminal, and only needs to increase the power supply and external power amplifier. It can be used as a single device, or integrated in other audio devices (power amplifier, or active speakers, etc.), making it a network audio playback terminal.
The broadcast host can use our company's broadcast system control software, broadcasting equipment, network microphone, etc., or the user can develop his own broadcast software based on our company's DLL dynamic library. Both the playback software and the playback development kit use our company's private protocol, and only support the playback of our company's equipment modules. As a playback terminal, the network audio module uses our proprietary protocol for playback control, and can only be used in a LAN or VPN intranet. In fact, customers can also choose to develop their own playback software of SIP protocol, which can be used in LAN or Internet.
