sinrey
Newbie level 5
SINREY SIP2401V supports a variety of network protocols and audio codec protocols, and can be used for applications such as VoIP and IP paging, and high-quality music streaming media playback.
• Temperature: Operating temperature range Industrial grade: -20~55℃
• Network interface: 10/100M Base adaptive Ethernet interface
• Mic/LineIn: typical amplitude 1000mVrms, signal-to-noise ratio 95dB
• Line Out : load 10KΩ, typical 1000Vrms, signal-to-noise ratio 95dB (in playback mode)
• Decoding mode: Provide stereo playback, up to 48kHz, 320kbps audio stream, support MP3, WAV (PCM +IMA ADPCM), G.711 a/u, G.722 and other formats.
• Encoding mode: Support G.711a/u, G.722 and RTP mode
• Two-way mode: two-way talkback, with high-performance echo suppression algorithm, G.711a/u, G.722 encoding
• Module size: length×width×height: 5×5×1.7cm
You can learn more through our website:https://www.sinrey.com/
Parameters
• Power input: voltage DC 4.7~16V• Temperature: Operating temperature range Industrial grade: -20~55℃
