The OP must offer a common mode range down to 0.5 V below negative rail. Not a common feature at least. I suspect an over-simplified simulation model.LTSpice sim image
Not by design. Need to notice that unbalanced source resistance can generate an offset.the resulting circuit has somehow a 50mV offset on the output, not sure where this is coming from.
The circuit looks O.K. now, check it.not convinced this will work
