aym_qunibi
Member level 4
i am using a triggering module for single phase vibrator, this inductive load affects the zero crossing detection of the supply voltage,so i have an intermittent output voltage, and the control voltage 210v t0 230.
i have used a lamp 100W in parallel and the problem solved [resistive load] but the heat generated by it is too high in the panel.
what i can do?
what i can do?
