rezaxyz
Junior Member level 2
single-ended differential cable line in
I want to transmit a single-ended analog signal over a distance, so I need a circuit to convert it to a differential signal.
I searched the web but it seems the common way is using “Fully differential amplifier”s. Since I can’t obtain this component, I need another way to do conversion. Can you suggest any circuit?
Thank in advance
Reza
Thank in advance
Reza
