[SOLVED] Single Ended inverting Buffer/Line Driver to invert a 24V logic signal square signal
flote21
Advanced Member level 1
Hello folks,
I am wondering if there is a comercial part which is able to invert a square signal from 0 to 24V. The most of the comercial buffers and Line drivers that I found dont support 24V of power supply.
I have trying to do it with an Op Amp configured in inverting mode but it is not working.
PS: The maximum frequency of the square signal is 9KHz.
Thanks a lot!
Regards,
EP.
An OP amp set up as an comparator ought to work - provided the OP amp output can swing to the rails. You might be able to get away with using a bjt configured as a common emitter amplifier.
By "invert" do you mean change the phase by 180°?
If so, just use a transistor common-emitter inverter stage.
Most half-decent opamps have maximium supply voltages of 36V and 44V so 24V is no problem. They work well up to at least 100kHz.
A 741 opamp was designed 47 years ago and has trouble above 9kHz.
Unstated parameters include:
- output current / load impedance
- amplitude fidelity and how close to supply rails
A power MOSFET driver (at least some of them)
could be a simple way to smack a low impedance
load around. Unlikely to have a 0-24V input (some
may, but TTL-ish is the norm) but a resistor divider
at the input could fix that. Many types have
inverting inputs.
yessss
a BJT configured like common emitter is exactly the solution that i need!
Thanks everybody!!!
