[ARM] single edge PWM in LPC2138
eric_s88
Hi everyone! happy to joined you in this forum :wink:
I want to have 2 single edge pwm (pwm6 and pwm1) in outputs of lpc2138. but I don't know why I have only one pwm signal!! I mean when I activate them only 1 output generate the signal. I want 2 signals that are inverted and non-inverted :( whats wrong with the code ?
I use IAR as compiler.
in its library I have:
void pwm6_init(void)
  PWMPR=0x00000DFF;
  PWMPCR|=(1<<14);
  PWMMR0=0x000000FF;
  PWMMCR=0x00000002;
  PWMTCR=0x00000002;
  PWMTCR=0x00000009;
  PINSEL0|=(1<<19);
void pwm6_out(us32 value)
  PWMMR6=value;
  PWMLER=64;
void pwm1_init(void)
  PWMPR=0x000003FF;
  PWMPCR|=(1<<9);
  PWMMR0=0x000000FF;
  PWMMCR=0x00000002;
  PWMTCR=0x00000002;
  PWMTCR=0x00000009;
  PINSEL0|=(1<<1);
void pwm1_out(us32 value)
  PWMMR1=value;
  PWMLER=2;
and in the main.c
void main (void)
 pwm1_init();
 pwm1_out(127);
 pwm6_init();
  pwm6_out(230);
  while(1)
hi again. I found the problem. it was the PWMLER register that I did not set correct.
another question. I want one of this 2 signals, be inverted (starts with 0 value) .. which register would do that for me?
