sinewave clock to square wave
karote
diode 1ss99
I need to convert 250 low jitter sine wave clock to square wave or so called clipped sine wave. Could anyone propose suitable circuitry. I'm thinking of using fast diodes to clip the sine wave, but so far the signal shape has been something else than clipped sine, more like a trianngular wave. Maybe my diodes have too much capacitance. But if someone could propose suitable circuitry and also suitable diode type. The sine wave swing is about 3 Vpp.
Thanks in advance
It depends on the application. If the duty cycle must be controlled very well, a comparator is the best choice. If not an amplifier with large gain and the sinewave AC coupled into the input might also work at lower cost.
But, in case I want to use clamping diodes, can anyone give advice about how to do it ? And also propose a diode type. The clock frequency was 250 MHz
Dear,
Check these diodes from Agilent Technologies (now:Avago Technologies)
HSMS-285x series
HSMS-286x series
and 1ss99 from NEC (i think,may be Toshiba)
Good Luck!
