Sine wave generator circuit
PA3040
Advanced Member level 3
Dear All,
I want show to school student about Rectification and AC to DC covert / DC Smooth circuit using Capacitor
For this I need to use a transformer which is high voltage
Therefore I have decided to make a Sine wave generator using simple circuit , Then I can ignore the Transformer
Please advice the tested Sine wave generator that I can Use for rectification
It also better if we can change the frequency fro 0 to 60
Thanks in advanced
How a bout a common garden mains transformer that steps down to 12Vac and then put a 10 ( 20W ) ohm resistor on it to limit the current to 1.2A rms - a lot easier I think - and safe.
Frequency controller is the issue
Any ready to buy sinewave generator,
Or a PC or cellular phone with audio output (plus APP to generate the desired frequencies)
and a DC coupled audio amp.
Klaus
as above, sig gen and audio amp .... 50W ( internally protected ) ....
Simple square-wave oscillator made from inverter-gates. Add a third inverter to create bipolar AC at the load.
A large capacitor smooths the waveform so it is sine-like.
To vary frequency put a 1M potentiometer for the 300k resistor.
If you make the diode bridge from led's then it increases the visual impact as they flash alternately. Careful not to overload the led's.
Any ready to buy sine wave generator,
Klaus
Yes...This is the modern solution . I am really appreciate
You mean Installed the Frequency Generator app to Smart phone , Then we can send the waves to as a sine waves by amplifying using single transistor and then we can use it for AC to DC converter
Grate thanks
I don´t know your requirements regarding voltage, current, precision and so on.
Thus I don´t know whether a single transistor would work..
But it should work as simple tool to "show" how an AC to DC rectifier works.
Klaus
For low voltage circuits, so that you could show the principle you are looking for with even just a battery as the power supply, and where a beautifully perfect sine wave is not a strict requirement, a 'Wein Bridge Oscillator' or a 'Low Frequency Sine Wave Generator with Quadrature Output' (one signal is a horrible 'sine wave', the other quite good) could work. See AN-31, Op Amp Circuit Collection, section 2 'Signal Generation' for such circuits. This could be rectified with a precision full-wave rectifier circuit or just a diode bridge. Op amp sine wave generator and rectifier circuit could be a way of showing the uses of op amps and AC-DC rectification.
What about a tiny transformer with very low output current capabilities. I have a dual output 220VAC to 12VAC transformer that can only output ~70mA - it is about 5x5x5cm. That would be good for adding a diode bridge and showing ripple vs capacitance, bad for having to make the thing and add fuses, even if it is a small circuit.
Reactions: PA3040
    PA3040
Thanks
I also think Tiny Transformer is very reliable and user friendly and less complicate . How ever it is grate if we can go to more handy method, That using Mobile phone Frequency generator by the app, . I made a single transistor amplifier in the breadboard for testing , I connected a LED to output and connected Mobile phone jack to input but it wasn't success
Please focus on technical descriptions, show the schematic and give a detailed error description.
Klaus
    PA3040
