sine wave generation in vhdl
matt2011
I am very new to vlsi......
I want to generate a sine wave using vhdl.
i stored all the samples in a rom and fetch one by one to generate it.my main aim is to change the phase of the sine wave for 45,90 degrees...pls help
treqer
Full Member level 3
Russia
determine the frequency. In any case. to generate a sine with a frequency of 1 MHz with an accuracy of 100 points for the period necessary to touch these points at 100 megahertz.
See DDS synthesizer on FPGA
---------- Post added at 11:14 ---------- Previous post was at 11:12 ----------
jumps to address its ROM. Get an instant jump in the phase
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
To advance 90 degrees, you skip ahead ninety 360ths ( or 25 percent ) of a cycle.
The amount of samples you should skip depends on how many divisions you use per cycle.
Example, if you use 1000 divisions for a cycle, then skip ahead 250.
If your units are radians, then a full cycle is 2*Pi. The proportion is calculated the same way. 90 degrees is Pi/2 radians.
jimwu88
Member level 3
dpaul
Germany
I had used Taylor series expansion to generate sine & cosine waves. You can select the no. of terms to give a accurate looking waveform in the simulator!
jimwu88
Member level 3
Check the "VHDL functions" section in this "Memory Initialization Methods" blog
