Simulation running fine, but hardware not working according to simulation
waqar86
Junior Member level 2
i have a transmitter(upto 1 megabaud) and a receiver(0.1 Megabaud - 1 MegaBaud) where i have to avoid the link going down between transmitter and receiver when the transmitter isn't sending data. So i thought of a scheme with state machines i-e,
Transmitter Side,
when data_in = 0 then sequence 10 is sent to receiver in two states(i-e 2 clk cycles)
when data_in = 1 then sequence 01 is sent to receiver in two states(i-e 2 clk cycles)
when data_in = x then sequence 11 is sent to receiver in two states(i-e 2 clk cycles)
Receiver Side,
when 10 is received(means data_in=0) from transmitter, it is sampled in 4 clock cycles as 1 1 0 0
when 01 is received(means data_in=1) from transmitter, it is sampled in 4 clock cycles as 0 0 1 1
when 11 is received(means data_in=x) from transmitter, it is sampled in 4 clock cycles as 1 1 1 1
Everything runs fine with simulation, but when i test it with function generator i don't get correct output, i think i am unable to synchronize data_in correctly with the code or may be i am missing some cases of data_in or may be its problem with the clock. If anyone can guide me a bit it will be highly appreciated.
Tranmitter Code
entity transmitter is
		port(
		data_in :in std_logic;
		CLK  :in std_logic;
		output_to_fibre :out std_logic
--		final_output :out std_logic
end transmitter;
architecture Behavioral of transmitter is
--signal CLK_REC	:std_logic;
signal NEWCLK_HALF	:std_logic;
--signal output_to_fibre :std_logic;
    type state_type_tx is (state1, state2);
	 signal next_state_tx: state_type_tx;
begin
clk_half:PROCESS(CLK)
VARIABLE COUNT:INTEGER:=0;
   BEGIN
      IF CLK='1' AND CLK'EVENT THEN
         COUNT:=COUNT+1;
            IF COUNT<=10 THEN
               NEWCLK_HALF<= '1';
            ELSif COUNT>10 and COUNT<20 then
               NEWCLK_HALF<= '0';
					elsif COUNT=20 then
					COUNT:=0;
            END IF;
      END IF;
END PROCESS clk_half;
TX_logic:process(NEWCLK_HALF)
variable i : integer :=0;
--variable start: integer:=0;
begin
if (NEWCLK_HALF'event and NEWCLK_HALF='1') then
	case next_state_tx is
		 when state1 =>
			if data_in ='0' then
			    next_state_tx <= state2;
				 output_to_fibre <= '1';
			elsif data_in ='1' then
				 output_to_fibre<= '0';
			else
				 output_to_fibre<= '1';
			end if;
		 when state2 =>
			    next_state_tx <= state1;
				 output_to_fibre <= '0';
			else
			end if;
	end case;
end if;
end process TX_logic;
end Behavioral;
Receiver Code:
entity receiver is
port(
		CLK :in std_logic;
		input_to_receiver :in std_logic;
end receiver;
architecture Behavioral of receiver is
type state_type_rx is (initial_state, one_state1, one_state2, one_state3, z_state1, z_state2, z_state3, state_carrier_rx);
signal next_state_rx: state_type_rx;
begin
clk_2:PROCESS(CLK)
   BEGIN
         COUNT:=COUNT+1;
            IF COUNT<=5 THEN
               CLK_REC<= '0';
            ELSif COUNT>5 and COUNT<10 then
               CLK_REC<= '1';
					elsif count=10 then
					COUNT:=0;
            END IF;
      END IF;
END PROCESS clk_2;
RX_logic:process(CLK_REC)
begin
if (CLK_REC'event and CLK_REC='1') then
	case next_state_rx is
		when initial_state =>
			if input_to_receiver='0' then
			    next_state_rx <= one_state1;
				 final_output <= '1';
			elsif input_to_receiver ='1' then
			    next_state_rx <= z_state1;
				 final_output <= '0';
			end if;
		when one_state1 =>
			    next_state_rx <= one_state2;
			end if;
		when one_state2 =>
			if input_to_receiver='1' then
			    next_state_rx <= one_state3;
			end if;
	    when one_state3 =>
			    next_state_rx <= initial_state;
			end if;
		 when z_state1 =>
			    next_state_rx <= z_state2;
			end if;
		when z_state2 =>
			if input_to_receiver ='0' then
			    next_state_rx <= z_state3;
			elsif input_to_receiver = '1' then
				 next_state_rx <= state_carrier_rx;
				 final_output<= 'Z';
			end if;
		when z_state3 =>
			end if;
		when state_carrier_rx =>
				final_output <= 'Z';
	                end if;
	end case;
end if;
end process RX_logic;
end Behavioral;
Top_Module:
ENTITY top_module IS
port (
		data_in : in std_logic;
		CLK : IN  std_logic;
      output_to_fibre : OUT  std_logic;
END top_module;
ARCHITECTURE behavior OF top_module IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT transmitter
    PORT(
         data_in : IN  std_logic;
         CLK : IN  std_logic;
    END COMPONENT;
	 COMPONENT receiver is
	 port(
		CLK :in std_logic;
    END COMPONENT;
BEGIN
	-- Instantiate the Unit Under Test (UUT)
   uut: transmitter PORT MAP (
          data_in => data_in,
          CLK => CLK,
          output_to_fibre => output_to_fibre
	uut2: receiver PORT MAP (
			CLK =>CLK,
			input_to_receiver => input_to_receiver,
			final_output => final_output
END;
