simulation of ti parts with pspice
whatever125
I'm trying to simulate a part with TI's CSD25401 everytime I try to run the simulation it says the subcircuit is missing. I have all the files needed for that part in the same folder as my simulation file and it still doesn't work.
I have version 16.0 and this should work but it's not and I'm not sure why.
You need to add the lib file in the simulation settings. Do following -
Simulation -> Edit Profile-> Configuration Files (Tab) -> Library (under category). Browse for the lib file and "Add to design".
This should resolve the problem.
Still didn't work. Same error
Ok. Can you share your netlist and lib file.
By looking at netlist , should be easy to figure out root cause of the error.
