goodpranoy
Junior Member level 3
- Joined
- Dec 5, 2013
- Messages
- 29
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 201
hi guys,
i am getting these errors and warnings in the transcript
# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).
# Time: 0 ns Iteration: 0 Process: /tb_top/mapping/data/register_b/line__22 File: C:/Documents and Settings/Pranoy tm/Desktop/qwerty/register_new_collage.vhd
# Break in Process line__22 at C:/Documents and Settings/Pranoy tm/Desktop/qwerty/register_new_collage.vhd line 24
this is the program
this is the program
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity reg_new is port( control:in std_logic; data_in:in std_logic_vector(7 downto 0); reg_enable:in std_logic; data_out:out std_logic_vector(7 downto 0); a_zero_status:out std_logic; clock:in std_logic ); end reg_new; architecture behav of reg_new is subtype cell is std_logic_vector(7 downto 0); type memarray is array(0 downto 0) of cell; signal mem:memarray; begin process(mem(0)) begin if(mem(0)="00000000") then a_zero_status<='1'; else a_zero_status<='0'; end if; end process; process(control,clock) begin if (clock'event and clock='1') then if reg_enable='1' then case control is when '1'=> data_out<=mem(0); when '0'=> mem(0)<=data_in; data_out<=(others=>'Z'); when others=> data_out<=(others=>'Z'); end case; end if; end if; end process; end behav;
