shnuk
Newbie level 1
Hey all,
I wrote Verilog code in modelsim that describe clock divider to 5, I did a simulation to verify that the code is right.
Then I took this code to Quartus in order to see RTL schematic. in order to see RTL schematic I should change the code, the code I wrote didn't pass synthesis.
I have 2 always codes controlled the same output. In modelsim it works fine, in Quartus it didn't, sensitive list I changes to from always@(poedge clock, reset) to always@(poedge clock, negedge reset).
Why there is a different?
does the code I wrote for Altera FPGA will work with Xillinx too?
What is the difference between "ModelSim-Altera 6.1g (Quartus II 7.2) Web Edition" and "Modelsim SE 6.6b"?
Thanks ahead
Thanks ahead
