is it possible to use some part designed by Verilog or VHDL with other schematic circuits ?
for example I designed a three bit digital counter and I want to put this counter with the other elements like operational amplifier and resistor to build simple flash converter.
I have tried to do it but the the simulator is refusing to simulate
You can define the "Views" by Configuration Editor so the Spectre simulator uses corresponding views while simulating.
Another option is to create "Partitions" as I know so the partitions are simulated by their corresponded simulators.
Thank you Boss for your reply,
I am sorry to tell you I could not find the setting you are referring in your explanation, it would be very kind of you if you refer me to more details or picture setting
