Simple Wheather Station
Slayerza
Full Member level 5
South Africa
wheather station
I need some idea for a weather station. I don't need all of the temp/humidity stuff all I really need is the wind speed and direction. This has to be done on a budget for as cheap as possible.
I have looked at some of the commercial products but the cost is too high for my purposes. I wish to connect this to a micro controller and transmit the readings via SMS. The latter part MCU->SMS is allready working fine.
Cheers
Slayer
transistor anemometer
1) Try using a Stepper Motor to get direction (use a reference then count the steps taken to settle down)
2) Use a DC motor to get speed (A to d converter)
transistor trio makes vector anemometer
make a mechanical structure which moves 360 degree controlled by stepper motor. A simple turbane(just like wind station) is over the shaft of the stepper motor to detect speed. To determine speed count the number of spikes per second or the time taken b/w two spikes(you should know the distance b/w two spikes and all the spikes should be equidistant). Calculate speed by using this. First choose a reference point. Move stepper motor 360 (one rotation) and find the point at which max speed is obtained, that will be the direction of wind.
Bibin John
www.bibinjohn.tk
transistors anemometer
hi,
i think u can use the VHF TX and RX modules for communication form the base station
techdesign.be good to buy stuff?
Hi!
Some time ago I started a project to reproduce the weather station from this link: https://www.techdesign.be/projects/012/012.htm
it seems to be a good project, but my progress is minimal until now, since last week I was finishing my master thesis.
Now, I´m currently, trying to implement an anemometer to this project, and by now i´m implementing this anemometer circuit: Transistor linearly digitizes airflow **broken link removed**
but this version is not able to provide direction wind data.
there is another project from the same author, but the graphics aren´t good, but you can try: Trio Transistor makes vector anemometer
https://www.edn.com/archives/1997/090197/18di_03.htm
I will aprecciate if you post your progresses here.
best regards;
Grabauska
Brazil
