Simple usb interfacing project in vb6
daredave
Newbie level 3
philippines
good day sir! i need help about usb interfacing in vb6.. Can someone provide me a sample of a simple project in vb6 with usb interfacing..like controlling the on/off of a LED thru usb and in the vb6 form there is a on/off command button..or chose a number in vb6 form and it will display it in a 7segment..thanks a lot sir!
bassa
Super Moderator
Staff member
Sri Lanka
You can build a small circuit and control it via PC's USB port using VB6. follow the link to find out the USB support chips from FTDI.
Products
And also use the search facility available in the forum
Ex: some forum's topic
Can I use Visual Basic 6.0 to access USB Port ?
hope this helps to reach your goal
regards
bassa
daredave
Newbie level 3
philippines
it help a lot sir! only problem is that the ftdi ic is not available here..it must be order and it will took about a week to arrive..i dont have much time to wait..^^.. i'll go look for similar topics..thanks a lot sir!
