update on air flow meter
I did experiment with pt1000 today.
I did use two bridges each having one pt1000 as a sensor and one of the resistors was 1.2k. as a result the pt1000 was heated to reach 1.2k.
Its like having two anemometers, one of them was subjected to air flow and the other was like a reference. and the outputs from these two was given to a differential amplifier to amplify the difference between the two. I did get it working, when no air flows the diff output is 0.13v and on air flow depending on the amount of airflow it increased to 3.0v.
could u suggest what needs to be done further to get it to a uc and the AVR part plz....
