Simple SBC for project use
L
lynchaj
Hi! I designed a single board computer for project use. It is designed for simple reliable construction. I think it would be ideal for educational use. There are over a hundred builders of the SBC. There is a backplane the SBC can optionally plug into and there are several peripherals available. The SBC has a Z80 CPU, parallel IO (8255), serial IO (16550), RTC (DS1302), 512K SRAM, 1M ROM, runs boots from ROM to run CP/M and/or RAM monitor. Expands using the ECB bus.
If you are interested in using this SBC for your school projects as a student or teacher please contact me. All hardware and software design information is freely and publicly posted. The entire design is open and free. We are always looking for new members in the N8VEM home brew project. The Eurocard ECB PCBs are $20 each. The N8VEM home brew computing project is entirely amateur and non-commercial.
https://groups.google.com/group/n8vem
Thanks and have a nice day!
Andrew Lynch
Hi! Here is a wireless network system one of the N8VEM builders created using the N8VEM system. He ended up making a customized version of the SBC for his application along with a variety of other things. This is an illustration of some of the projects that N8VEM builders are doing. There are other projects in work as well.
Andrew Lynch
