Simple Pulse LED driver circuit
ezpcb
Banned
attiny13 rgb
Hi all
I'm thinking of building a pulse led driver circuit. Rather than just flick on then off,
the led slowly up to full brightness then down again, cycling every 1 to 1.5 seconds. A triangle wave generator can do that, but I need the circuit to be as simple as possible. Could anyone post some circuit for reference? many many many thanks
Mike
www.ezpcb.com
IanP
Advanced Member level 5
West Coast
attiny13 rgb led source
If you know PIC mcrocotrollers you can directly drive a LED from their 8-pin device, the PIC12C671, more info here: https://www.rentron.com/PIC12C67X.htm .
With almost none external components you should be able to implement PWM routines to "slowly" turn LED on and off ..
ezpcb
Banned
Thanks IanP, but I need a circuit that can be mount in a 8mm by 10mm micro PCB, is that possible?
I'm thinking about design a chip for that application.
mike
glenjoy
Banned
Philippines
You can create one using a multivibrator and an RC delay.
ezpcb
Banned
I'm afraid RC delay circuit don' have enough current to drive led
silvio
Advanced Member level 3
Romania
Havanother it's employer in ezpcb company ?
This page incluse the source code for MC68HC908QT2CFQ
If you order like this you get one in DFN package.
https://elecdesign.com/Articles/Index.cfm?AD=1&AD=1&ArticleID=9254
You can try with Attiny12 or better new ATtiny13 since both have internal oscillator (like Motorola too) and 8 pins SOIC package.
Look here :
including source code https://elm-chan.org/works/tiny/lv12.asm.txt
https://elm-chan.org/works/tiny/report.html
It's for RGB LED but you can use only one either PB0 or PB1 or PB2 output and get rid of the ones attached to PB3 and PB4.
See diagram bellow:
gidimiz
Advanced Member level 1
Hi ezpcb,
If you do want to use the RC then you can use a Transistor or FET to increase your power to the LED.
There are a lot of diffrent circuits to make a sine wave, but all of them will output very low power. All you need now is to increase your power with one of the methodes I mentioned before.
Good luck.
ezpcb
Banned
gidimiz said:
Hi ezpcb,
Good luck.
I know at least 50 ways of increasing the power, but now of them is possible to fit in 8mm by 10 mm pcb.
But now I'm feeling myself a very stupid guy. I found a LED with built-in controller that can pulse like the way I want without any external circuit.
Anyway, thanks to everybody, you are so kind to me
mike
Added after 10 minutes:
h**p://elecdesign.com/Articles/Index.cfm?AD=1&AD=1&ArticleID=9254
Look here :
including source code h**p://elm-chan.org/works/tiny/lv12.asm.txt
h**p://elm-chan.org/works/tiny/report.html
See diagram bellow:
haha, I am the employer of Havanother. they ask me how to, I design a 8mm by 14 mm board, but I'm trying to make a board of 8mm by 10mm, so I ask for help here. Now it's OK, I had build a 1.5mm by 1.5mm chip to fit-in LED package
mike
