"One of the problems with the Armstrong method is that the frequency deviation—the amount of modulation—must be kept small to minimize distortion.[4] The maximum deviation is a fraction of 1 kilohertz, but FM broadcast requires 75 kilohertz deviation and a typical FM voice channel deviation is 5 kilohertz. To solve this problem, Armstrong multiplied the signal many times to a higher frequency to obtain the necessary deviation. For example, to generate an FM signal with 5 kilohertz deviation at 146.94 megahertz, the transmitter would generate a signal at 6.1225 megahertz with only 0.2 kilohertz deviation, and then multiply the signal 24 times."
