nuwakaka22
Newbie level 5
PIC16F628A Simple Combination lock Project with keypad and LCD
Hello, I have problems in my programming for my diploma project. Please correct my program for me to achieve build succeeded in MPLAB IDE. It comes success to be in Proteus simulation but for hardware. The errors must be fixed. **broken link removed**
this is my programming.
unsigned char var1, var2, kp;
char attempts=0;
char state = 1;//start from state 1
char txt[4];
char text[] = "Combination Lock" ;//message text
char text1[]= " *Door1 On*";
char text2[]= " *Door2 On*";
char text3[]= "*Door1&2 On*";
char table[17] = {0,1,2,3,0,4,5,6,0,7,8,9,0,10,0,11,0};
void main(void) {
CMCON = 0x07 ;//PORTA to digital mode
LCD_Config(&PORTA,7,6,5,3,2,1,0) ;//Pin assignment
;//RS,E,RW,D7,D6,D5,D4
LCD_Cmd(LCD_CLEAR) ;//Clear display
LCD_Cmd(LCD_CURSOR_OFF) ;//Turn cursor off
LCD_Cmd(LCD_SECOND_ROW) ;//Move to ROW2 for rest of program
//Seup Keypad on PORTB
Keypad_Init(&PORTB) ;// Initialize Keypad on PORTB
LCD_OUT(1,1,text) ;//Print welcome message
while(1) { //while ever loop
switch(state){ //check the current state
case 1:
LCD_out(1,1,text);
LCD_out(2,1,"EnterPass:");
while(!keypad_Read()){} //wait for key1 press
Delay_ms(10) ;//debounce time
kp = Keypad_Released() ;//wait for release
var1=kp; //store var1 into kp
var1=table[kp];
ByteToStr(var1,txt);
Lcd_Out_Cp(txt);
state = 2;
break;
case 2:
if(kp==15) state=1; //go back state 1 when kp = # (enter key)
else if(kp==13) state=1;//go back state 1 when kp = * (clear key)
else
state = 3;//go to state 3 get key2
break;
case 3:
while(!keypad_Read()){} //wait for key2 press
var2=kp;//store var2 into kp
var2=table[kp];
ByteToStr(var2,txt);
Lcd_Out_Cp(txt);
state=4;
break;
case 4:
if(kp==15) state=1;//enter key goes back state 1
else if(kp==13) state=1;//clear key goes back state 1
else
state = 5;//continue goes to state 4
break;
case 5:
while(!keypad_Read()){} //wait for enter key press
state = 6;
break;
case 6:
if(kp==13)
state =1; //clear goes back to s1
else if(kp==15)
state = 7;//enter key goes to state 7
else state = 5;
break;
case 7:
if (var1==0 && var2==5)//comparing for door1
state = 12; //goes state 11 open door1
else state =8;
break;
case 8:
if (var1==2 && var2 == 8)//comparing for door2
state = 13;//goes to state 9 for door 2
else state=9;
break;
case 9:
if(var1==8 && var2 == 2) //comparing foor door3
state = 14; //goes to state 15 for door 3
else state =10;//goes next state
break;
case 10:
if (var1==3 && var2 == 3)
state = 15;//goes to state 14 for door1 & 2
else
state =11;
break;
case 11:
LCD_OUT(2,1,"**Invalid Code**") ;
attempts++; //increment attempts
kp+=attempts;//kp = kp + attempts
if(attempts < 3) //attempts less than 3 times
state=1; //go state 1
else
state=16;
LCD_Cmd(LCD_CLEAR);
break;
case 12://open door1 for 5secs
LCD_Cmd(LCD_CLEAR);
Lcd_out(2,1,text1) ;
Lcd_out(1,1,text);
//turn door1 led on
PORTA.F4=1;
PORTB.f4=1;
PORTB.F7 = 0;
PORTB.F6 = 0;
PORTB.F5 = 0 ;
Delay_ms(5000); //delay 5secs
//turn door1 led off
PORTA.F4 = 0;
attempts=0;
state=1;
break;
case 13: //open door2 for 5secs
LCD_Cmd(LCD_CLEAR);//clear display
LCD_OUT(2,1,text2);
Lcd_out(1,1,text) ;
//turn door2 led on
PORTA.F4=1;
PORTB.F5=1;
PORTB.f4=0;
PORTB.f6=0;
PORTB.f7=0;
Delay_ms(5000);
PORTA.F4 = 0 ;//turn door2 led off
LCD_Cmd(LCD_CLEAR);
attempts=0;
state =1;
break;
case 14: //open door3
LCD_Cmd(LCD_CLEAR);
LCD_OUT(2,1," *Door3 On*");
Lcd_out(1,1,text) ;
PORTA.F4=1;
PORTB.F4=0;
PORTB.F5=0;
PORTB.f6=1;
PORTB.f7=0;
Delay_ms(5000);
PORTA.F4 =0;
LCD_Cmd(LCD_CLEAR);
attempts=0;
state =1;
break;
case 15: //open door1 and door2
LCD_Cmd(LCD_CLEAR);
LCD_OUT(2,1,text3);
Lcd_out(1,1,text) ;
PORTA.F4=1;
PORTB.F4=1;
PORTB.F5=1;
PORTb.f6=0;
PORTb.f7=0;
Delay_ms(5000);
PORTA.F4 = 0 ;
LCD_Cmd(LCD_CLEAR);
attempts=0;
state =1;
break;
default:// must be a bad attempts
LCD_OUT(2,1," **Alarm On**");
LCD_OUT(1,1,text);
PORTA.F4=1;
PORTB.F4=0;
PORTB.F5=0;
PORTb.f6=0;
PORTb.f7=1;
Delay_ms(5000);
PORTA.F4=0;
LCD_Cmd(LCD_CLEAR);
attempts=0;
state = 1; //goes to state 1
break;
}View attachment pic-combination-lock.zip
char attempts=0;
char txt[4];
void main(void) {
case 1:
LCD_out(1,1,text);
var1=table[kp];
Lcd_Out_Cp(txt);
state = 2;
break;
case 2:
else
break;
case 3:
var2=table[kp];
Lcd_Out_Cp(txt);
state=4;
break;
case 4:
else
break;
case 5:
state = 6;
break;
case 6:
if(kp==13)
else if(kp==15)
else state = 5;
break;
case 7:
else state =8;
break;
case 8:
else state=9;
break;
case 9:
break;
case 10:
else
state =11;
break;
case 11:
else
state=16;
LCD_Cmd(LCD_CLEAR);
break;
LCD_Cmd(LCD_CLEAR);
Lcd_out(1,1,text);
//turn door1 led on
PORTA.F4=1;
PORTB.f4=1;
PORTB.F7 = 0;
PORTB.F6 = 0;
PORTB.F5 = 0 ;
PORTA.F4 = 0;
attempts=0;
state=1;
break;
LCD_OUT(2,1,text2);
Lcd_out(1,1,text) ;
//turn door2 led on
PORTA.F4=1;
PORTB.F5=1;
PORTB.f4=0;
PORTB.f6=0;
PORTB.f7=0;
Delay_ms(5000);
LCD_Cmd(LCD_CLEAR);
attempts=0;
state =1;
break;
LCD_Cmd(LCD_CLEAR);
Lcd_out(1,1,text) ;
PORTA.F4=1;
PORTB.F4=0;
PORTB.F5=0;
PORTB.f6=1;
PORTB.f7=0;
Delay_ms(5000);
PORTA.F4 =0;
LCD_Cmd(LCD_CLEAR);
attempts=0;
state =1;
break;
LCD_Cmd(LCD_CLEAR);
LCD_OUT(2,1,text3);
Lcd_out(1,1,text) ;
PORTA.F4=1;
PORTB.F4=1;
PORTB.F5=1;
PORTb.f6=0;
PORTb.f7=0;
Delay_ms(5000);
PORTA.F4 = 0 ;
LCD_Cmd(LCD_CLEAR);
attempts=0;
state =1;
break;
LCD_OUT(1,1,text);
PORTA.F4=1;
PORTB.F4=0;
PORTB.F5=0;
PORTb.f6=0;
PORTb.f7=1;
Delay_ms(5000);
PORTA.F4=0;
LCD_Cmd(LCD_CLEAR);
attempts=0;
break;
