simple audio geneation on sparatn 3an
fpga.vhdl
Newbie
i want to store one audio clip in buffer of fpga and then it is converted using dac and played via 3.5 mm jack available on spartan 3an. can you plz provide me the code
Instead of searching or writing code for you...
a) use google and search for a similar project and modify it.
b) pay someone to develop the code for you.
c) develop the code yourself and use it as a learning opportunity to improve your design skills.
d) come back and ask specific questions when you get stuck while working on c or stuck with the second half of a.
BTW, c can be as simple as a bunch of block RAMs configured as a ROM and a counter to read the memory and output it to the DAC (with whatever interfacing and initialization requirements the DAC has)
