JohnJohn20
I have programmed a 16F628A chip to do the following:
1. Wait for a normally high input (RA6) to go low
2. Then flash an led (connected to RA0) 3 times
3. Wait until the input (RA6) goes high again
4. Then go back to step 1.
Seems simple enough except that when when I make the input high at step 3. it goes back to step 1. and rather than waiting there for the input to go low, the program jumps to step 2. and flashes the led again.
If I make the input high before step 2. has finished then the program behaves as expected and waits at step 1..
I suspect that this issue has something to do with the input value not being updated in the chip but everything looks OK to me. Please check the program below.
Or, if the programming is OK, could it be the input is "bouncing" and false triggering. In this case what is a programming solution?
Thanks.
Here are the relevant parts of my ASM code:
Yes well. It was indeed contact bounce. Solved it by putting a delay just before the goto Start instruction.
Thanks.
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 INT_VAR UDATA_SHR COUNT1 RES 1 COUNT2 RES 1 CycleCount RES 1 ORG 0x000 ; processor reset vector goto main ; go to beginning of program ORG 0x004 ; interrupt vector location ; isr code can go here or be located as a call subroutine ; elsewhere retfie ; Return from interrupt to main program main ;****Set up port and constants**** clrf PORTA movlw 0x07 movwf CMCON ; disable comparitors and set PORTs as I/O bcf STATUS, RP1 ;changes RP1 bit to 0 bsf STATUS, RP0 ;changes RP0 bit to 1: -> 01 - change to bank 1 movlw 0xFE ;11111110 movwf TRISA ; set RA0 as output and RA<1:7> as input ; RA0 OUTPUT : LED ; RA6 INPUT : Normally High = Wait bcf STATUS, RP1 ;changes RP1 bit to 0 bcf STATUS, RP0 ;changes RP0 bit to 0: -> 00 - back to bank 0 Start clrf CycleCount ; reset CycleCount to 0x00 btfsc PORTA,6 ; if RA6 high goto Start ; then cycle back to start FlashLed ; else flash LED bsf PORTA,0 ; turn on LED call QuarterSecDelay ; wait call QuarterSecDelay ; wait bcf PORTA,0 ; turn off LED call QuarterSecDelay ; wait call QuarterSecDelay ; wait incf CycleCount,1 ; increase CountCycle by 1 CheckFlashCount ; movlw 0x03 subwf CycleCount,w ; If CycleCount - w < 0 then STATUS,C = 0 btfss STATUS,C ; If CycleCount < 3 (ie STATUS,C = 0) goto FlashLed ; Then FlashLed again CycleReset ; else (CycleCount = 3) reset everything btfss PORTA,6 ; if RA6 low goto CycleReset ; then loop around until RA6 goes high again goto Start ; else go back to Start QuarterSecDelay decfsz COUNT1,1 goto QuarterSecDelay decfsz COUNT2,1 goto QuarterSecDelay return END ; directive 'end of program'
