I'm working on a breakout pcb for the SIMCOM SIM900D GSM IC. It's a basic breakout with the decoupling caps, TVS and simcard holder (with corresponding resistors per the datasheet) populated on the board and is being powered by an external power supply. Without the simcard inserted (prepaid T-Mobile in the USA) the unit powers up and I can issue AT commands with no problems and perform other functions.
When I put the simcard in the unit powers up, recognizes the simcard as being installed and then about 8 seconds later automatically powers down. I can't for the life of figure out why it's shutting off. I checked for proper voltage at the Vdd pin on the simcard, put a scope on it and saw a clean clock signal and also a lot of data transfer on the IO pin. One thing I must say is that the simcard is expired, however, it works fine in another breakout pcb that I have that uses a Telit GE865. I've sent SIMCOM an email asking if they have any recommendations but I have not heard back yet.
I'm going to desolder the simcard and wire up another externally to see if it's a pcb problem but I don't think it is. I'm also wondering if it has anything to do with certification in the USA. I see the SIM900 has been certified and accepted on the AT&T network but there is no info available on the SIM900D.
Any advice or recommendations on how to troubleshoot this problem further would be greatly appreciated. Thanks.
