SIM900D sending and receiving message using PIC16f84a
dark_ages
Member level 1
Koronadal City, Philippines
hi fellows...
we're on our final year in college and we've come up with an SMS based project. we need some help regarding on how to connect the SIM900D to the microcontroller and some codes in MPLAB IDE to controll the gsm modem.
any good help will be much appreciated....
dark_ages
Member level 1
i haven't tried it yet...i have read some page about testing it with the hyperterminal but the gsm modem there is not the sim900d, its benQ i think and it has a serial port in order to connect to the computer.
In case of sim900d, it doesn't have any serial port.
How could I test it?
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
simcom modems are all same and most of the AT commands are same....
you can test it with serial port and terminal and become aware of at commands and then start the program
dark_ages
Member level 1
sir....do you have any assembly codes in mplab there that can be used to enable the sim900 to text?to turn on?and to filter the messages that is received by the sim900?
zula
Full Member level 2
Turkey
you will talk to sim900d with UART. so you have to implement uart module. then you will send AT commands.
by the way, if you design your custom board, just keep in mind the PWRKY pins for the wake up sim900d.
dark_ages
Member level 1
now were using mikroC for our project,
but when I use the command Usart_Init(9600), Usart_Read_Text(), or Usart_write, it only provides me with errors,
but when i coded UART1_Write,UART1_Init(9600), and any other commands, it is accepted.
is there any initialization to be done first before using Usart commands?
seadolphine2000
Advanced Member level 3
You have to include the library in your project. There is a panel with the libraries those can included in your project, you have to select the "USRAT" library.
dark_ages
Member level 1
I'll try it...tnx a lot.....
another problem that i have encountered is that when I code:
void main(){
while(1){
if(UART1_Read_Text=="System On"){
what should I COde?
can u please send me some examples of sending and receiving sms mikroC code....
just email it to sajo_christian@yahoo.com....tnx a lot.
muwasif
Junior Member level 1
Karachi
you can send AT command on usart port like
const unsigned char at[]= "AT\rAT+CMGF = 1\rAT+CSCA =\"+<message center #>\"\rAT+CMGS =\"<Mobile #>\"\;
char msg[] = {"Test Message"};
Usart_Init(9600);// baud rate
i=0;
do {
Usart_Write(at);
} while (at[i++]!=0);
i = 0;
do {
Usart_Write(msg);
} while (msg[i++]!=0);
i = 0;
Usart_Write('\x1A'); //Clt+Z
i = 0;
