SIM600 and Sending Data over TCP/IP with GPRS?
BasePointer
Full Member level 2
TURKEY
send data via gprs
Now I'm working on SIM600 EVB kit and trying to send data over TCP/IP with GPRS.
I have some question with it. I can successfully attach to GPRS, but can't send any data via TCP/IP.
My GSM provider needs
APN: internet
User: gprs
Pass: gprs
I want to connect/send/receive my server has static IP: 78.XXX.XXX.108, port: 2222 with TCP. I can easily connect to my server with Motorola G24.
Please help me for required AT Commands and sequence.
AFTER POWER-UP the SIM600 EVB KIT:
+CFUN: 1
+CPIN: SIM PIN
at+cpin="1045"
+CPIN: READY
OK
at+cmee=2
OK
at+csq
+CSQ: 19,0
OK
at+cgdcont=1,"IP","internet"
OK
at+cgatt=1
OK
at+creg=1
OK
at+cgact=1,1
OK
at+cstt="internet","gprs","gprs" -> why ? :(
ERROR
at+ciicr
ERROR
at+cifsr
ERROR
at+cipstart="TCP","78.XXX.XXX.108","2222"
ERROR
Regards,
BP.
milind_gaonkar
Newbie level 1
at+cipshut
try this.....
AT+CSTT="AIRTELGPRS.COM","",""
OK
AT+CIICR
OK
AT+CIFSR
117.98.1.85
AT+CIPSTART="TCP","xxx.xxx.xxx.xxx","80"
OK
CONNECT OK
AT+CIPSEND
> hi,this is milind.
SEND OK
here "AIRTELGPRS.COM" is the APN(access point name) because i am using Airtel sim card.you can check it in your mobile.
If error occurs use AT+cipshut and then use at+cipstart.
    BasePointer
BasePointer
Full Member level 2
TURKEY
at+cifsr
milind_gaonkar said:
try this.....
As I learn, Sim600 doesn't support TCP/IP command set. So we switched SIM700 and it works perfect.
10x
movie_freak
Member level 5
sending password gprs
OK
hi guys.. if AIRTELGPRS.COM is the access point how can we configure or program a general embedded device with this module which can use any other acess point like that of idea's or vodaphone's or mtnl's
TekUT
Full Member level 6
Italy
how to send data over tcpip
try this.....
10x
Could you please report what is the price for such type of devices? (1 to 10 pieces).
Thanks
Pow
