SIM300C problem with connection
lukee
Junior Member level 3
I have big problem with connection with SIM300C. I have connected SIM300C throught EVB to my PC. I have created new connection at HyperTerminal (19200,8-N-1), but when connect to SIM300C, it haven't send any data.
What is wrong ?
Best Regards
Lukee
hi
it better use 9600,8n-1
at first time u connect to hyper the module work in auto band mode
type "at"
if it doesn't answered "OK"
check the wires &module power on LED that be correct , the module turned on on handle
then type "at+ipr=9600"
be success
Make sure you are using Serial1 and not Serial2[That's for debugging]
I haven't EVB
which pins should be connected to PC? and how?
