SIM300 getting no response from server after SEND OK
dpmjoshi
Newbie level 3
hi ,
i ve made the gprs connection using SIM300 but not getting any response from server, i want to open google home page on hyperterminal.
i ve used following commands:
AT+CGATT=1
OK
AT+CIPMODE=0
OK
AT+CGDCONT=1,"IP","aircelwap"
OK
AT+CSTT="aircelwap"
OK
AT+CIICR
OK
AT+CIFSR
10.182.152.119
AT+CDNSORIP=1
OK
AT+CIPHEAD=1
OK
AT+CDNSCFG="202.148.202.3","202.148.202.4"
OK
AT+CIPSTART="TCP","www.google.com",80
OK
CONNECT OK
AT+CIPSEND
ccept-Language: en-usxt/html /1.1
SEND OK
CLOSED
i think i am having problem while sending the http request , the problem is with <CR> <LF> .
please tell me if any have any sort of solution to it.
i ve already read that threat.
i have tried all the things written over there ,
but still not getting any response from server,
after SEND OK
10 min no response
and then CLOSED appears on my screen ,
i know that it is time out ,
but in between i should at least get error or some header from google .
have you check signal quality with AT+CSQ? can you send a SMS text message?
hi ,
you cannot open a webpage on hyperterminal..... it does not support http forrmat...
it gives some special characters which you need to save as .htm file and open it in explorer
no i have not checked it , but it is around 14 -19 but i am able to send the SMS.
It's actually an ASCII based protocol, so it could be (in principle) send in Hyperterminal, at least for test.
But I can't recognize a valid HTTP command in your test. The CIPSEND text should start with GET.
using a WISMO228 if initialise the modem and the TCP/IP stack and then send
at+wipcreate=2,1,"www.google.com",80
at+wipdata=2,1,2
GET x
I receive
'<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">'
'quested URL could not be retrieved</title>'
etc etc
