SIM300 - Connect Fail
nat_jacker
Newbie level 6
Hi all,
I am totally new in this GPRS/GSM Module. I have connected the module to hyperterminal and send the following command:
OK
AT+CREG?
+CREG: 0,1 //GSM network is OK
OK
AT+CGATT?
+CGATT: 1 //GPRS is active
OK
AT+CIPSTART="TCP","64.233.181.106","80" //connect to www.google.com
OK
STATE: TCP CONNECTING
CONNECT FAIL
It fails to connect. What did I do wrong?? What are the things that I need to check?
I am a total newbie with all this.
Look at this page **broken link removed** - it has a FAQ showing how to make a GPRS connection and send an HTTP request.
thx for the reply.
I have successfully connect to the web server but there are several things that I don't understand
Below is the command send:
AT+CGATT=1
OK
AT+CGDCONT=1,"IP","celcom.net.my"
OK
AT+CDNSCFG="208.67.222.222","208.67.220.220"
OK
AT+CSTT="celcom.net.my","",""
OK
AT+CIICR
OK
AT+CIFSR
10.188.225.160
AT+CIPSTATUS
OK
STATE: IP STATUS
AT+CDNSORIP=1
OK
AT+CIPSTART="TCP","www.google.com","80"
OK
CONNECT OK
AT+CIPSEND
> [the part don't understand]
what should I send here? do I have to wait for the webpage response or I have to type in:
GET / HTTP/1.1
Host: www.google.com
Connection: Keep-Alive
Accept: */*
Accept-Language: en-us
I am lost..pls help
The SIM300 sends the '>" when it has established a conneciton with the remote server and is ready to accept the HTTP data. Yes you send:
GET / HTTP/1.1
Accept: */*
Make sure to append a CTRL-Z to indicate that you are done sending data. The Module will then return the response from the server.
but I get nothing in response
AT+CGATT=1
OK
OK
OK
OK
AT+CIICR
OK
AT+CIFSR
10.191.252.165
AT+CIPSTATUS
OK
STATE: IP STATUS
AT+CIPHEAD=1
OK
AT+CDNSORIP=1
OK
OK
CONNECT OK
AT+CIPSEND
> GET / HTTP/1.1 Host:www.google.com Connection: Keep-Alive Accept: */* Accept-Language: en-us
SEND OK
CLOSED
Above is the command in window hyperterminal that I have send to my module.
I do not receive anything. What might have causing the problem??
Each of these lines
GET / HTTP/1.1
Accept: */*
needs to have a carriage return and line feed after it. Also, you need to send a blank line after that data - before the CTRL-Z.
I still can't get the server response.
Am using window hyperterminal.
After i receive ">",
First I type:
GET / HTTP/1.1 <Enter><Shift+Enter>
then:
Host: www.google.com <Enter><Shift+Enter>
however, in window hyper terminal, whenever i press enter it shall not go to newline.
It will overwrite the line before it:
> Host / HTTP/1.1 <Enter><Shift+Enter> ---->gets overwritten
please help. I have been trying this command for few days now. still can;t get it work.
I have check my sim and i can successfully surf google website via handphone.
Carriage <Enter> keystroke
Linefeed <Shift+Enter> keystroke
Are these correct??
If you check the box "Send line ends with line feeds" in the "Properties...Settings...ASCII Setup" screen it should send a carriage return and line feed when you hit the Enter key.
Reactions: zeilja
    zeilja
Thx, that shall do the tricks!
Now I can connect to google and receive from the website.
Added after 16 minutes:
the reply from the webserver is in HTML form.
Now after I have receive the reply, what can I do from here?
or is this just the indication that I am now well connected to the server??
what are these command for??
where shall I read this command?
GET / HTTP/1.1
Accept: */*
Is this connection to the server is somewhat works like a telnet?
If not, what should I do in order for it to work like telnet??
If you are connecting to Google, probably not much. However, you could have a server that returns useful data to you, or that alllows you to store data on it.
GET / HTTP/1.1
Accept: */*
This is an HTTP header. It provides information to the server about your request. You can Google "HTTP Header" for details.
No, an HTTP connection is nothing like a Telnet connection.
Investigate the Telnet protocol and write code to implement it.
thanks this topic realy help me...
i use sim900 have same problem..
now solve...thanks ....^_^
