SIM18 GPS Module Power OFF
lock19
Newbie level 3
Greetings!
I am currently working on a SIM18 - EVB_V1.02 (GPS Module Evaluation Board).
I am able to switch ON the unit by using the ON_OFF switch but am unable to switch OFF the unit.
Any help would be appreciated...
Best Regards
P.S. Right now, I am using the PWR_IN switch to switch OFF the unit. There should be an alternate way right...
Do you have any idea how to turn this on/off with a microconrtoller?
Reference SIM18 Hardware Design Guide, pg 18, Section 3.2.4 ON_OFF
The pulse to switch modes must be greater than 90us and less than a second.
Apparently, you alternatively could use a command to shutdown the SIM18:
Reference SIM18 NMEA Message Specification Guide, pg 26, Section 2.3.10 Message ID 117: Systems Turn Off
Hope the info helps,
BigDog
