[SOLVED] SIM 900 GSM module problem
ddmukundan
Newbie level 3
i have aproblem on interfacing GSM module with my dsPIC 30f4013.
when i send AT command the it is responding back with the same command i am not getting the response
i am sending like this
UART_TX[''A''];
UART_TX[''T''];
UART_TX[0X0D];
AFTER THAT I AM WAITING FOR RESPONSE
I AM GETTING
AT|| ON MY lcd
PLS ANY ONE KNOW THIS ISSUE PLS HELP ME
If your wiring is ok;
Can you try with 0x0A as terminating character instead of 0x0D ?
If didn't work try with both of characters at end.
Hello,
Did you try to communicate with modem without uC, for example with PC. Did u check baudrate? For more shematic is needed.
i connected UART TX to modem RX
modem TX to UART RX
i tried with AT<CR><LR> also i tried AT<CR>
for all these 2 i am getting the echo back. i dont think that if wiring is not ok i wont even get echo back. am i right?
Hello,
yes i try to communicate with PC hyperterminal and mikroc UART terminal
in both i am getting the correct response.
only when i sending using uc i am not getting the response
i set the baud rate at 9600 .
when i am connecting the uc with pc i am able to transmitt and receive as well
hello,
i have the same problem, that i am getting Eco back my same command that i am sending to sim 900a.
i am using mega 16 uc. i have checked all my hardware connection several times they are all correct.
can any one have solution??
