silk checking in PADS layout
arunrajendhar
Member level 3
India
Hi all,
I want to check the silkscreens which get overlapped with components, via pad, and comp outline
I'm doing it manually now and it takes much time.
Is there any possibility to check in pads or Is there any scripts available to check this?
Pls reply ASAP.
I don't have pads installed on my PC but if I remember correctly, in pads 2007 under tools--verify design you can check
fabrication and setup the minimum clearance between silkscreen and other things.
I hope this information can help you, I will verify the information once I am back from my vacation
Regards
