Salvador12
Full Member level 4
Ok, so I have known for a while that the laminations within AC cores exist to reduce eddy currents and provide a path for the field to "flow". I have read that the field actually travels along the laminations within the airgaps that exist between each lamination and then "diffuses" inwards into each lamination , this diffusion inwards is dependent on the skin depth corresponding to the AC flux frequency.
My interest is this, what if I have such laminations and the flux flows along their length, but at some point within such core, I create an airgap between each lamination , within this airgap I place a conductor that is parallel to the length of the laminations themselves, now what is the field direction in such case? Would the field point from one lamination into the next and cut the conductor perpendicularly or would the field point parallel to the both the laminations and conductor?
Please see the attached imagine , the black lines represent the individual silicon steel laminations, the red lines represent the conductor placed within the airgap between each lamination.
