Silicon Laboratories C8051F of mixed-signal microcontroller
haymeron
Member level 3
silicon 8051
https://www.silabs.com/products/microcontroller/applications.asp
AN133 AN133SW Embedded Ethernet Reference Design
AN145 AN145SW Three-Channel Power Sequencer
AN146 AN146SW High-Speed Lithium Ion Battery Charger
AN147 AN147SW Wireless Digital Full-Duplex Voice Transceiver
AN148 AN148SW Magnetic Stripe Reader
AN155 AN155SW Stepper Motor
Application Notes
App Note Software Description
AN101 AN101SW Configuring the Port I/O Crossbar Decoder
AN102 AN102SW Configuring the Internal and External Oscillators
AN103 AN103SW Using the On-Chip Temperature Sensor
AN104 Integrating Keil 8051 Tools Into the Silicon Labs IDE
AN105 AN105SW Programming FLASH through the JTAG Interface
AN106 AN106SW Interfacing an External SRAM to the C8051Fxxx
AN107 AN107SW Implementing 16-Bit PWM Using the PCA
AN108 AN108SW Implementing a Real-Time Clock
AN110 AN110SW 16-Bit PWM Using an On-Chip Timer
AN111 Using C8051Fxxx Devices in 5 Volt Systems
AN112 AN112SW UART In-Application Code Loading Examples
AN113 AN113SW Serial Communication with the SMBus
AN114 Hand Soldering Tutorial for Fine Pitch QFP Devices
AN115 AN115SW Software UART Examples
AN116 Power Management Techniques and Calculation
AN117 AN117SW Using the C8051Fxxx On-Chip Interface Utilities DLL
AN118 AN118SW Improving ADC Resolution by Oversampling and Averaging
AN119 Calculating Settling Time For Switched Capacitor ADC's
AN120 FLASH Security User’s Guide
AN121 Converting from the Metalink ASM51 Assembler to the Keil A51 Assembler
AN122 AN122SW Annotated 'C' Examples for the 'F02x Family
AN123 AN123SW Using the DAC as a Function Generator
AN124 Pin Sharing Techniques for the C2 Interface
AN125 Integrating Raisonance 8051 Tools into the Silicon Labs IDE
AN126 AN126SW Integrating Tasking 8051 Tools into the Silicon Labs IDE
AN127 AN127SW FLASH Programming via the C2 Interface
AN128 AN128SW Software SPI Examples for the C8051F30x Family
AN129 AN129SW Writing to FLASH from Application Code
AN130 AN130SW Code Banking Using the Keil 8051 Tools
AN131 AN131SW Porting Considerations from ’F02x to ’F12x
AN132 AN132SW Integrating Dunfield 8051 Tools into the Silicon Labs IDE
AN134 Multiple-Device JTAG Configuration in the Silicon Labs IDE
AN135 AN135SW Cache Optimizations for C8051F12x
AN136 Production Programming Options for Silicon Labs Devices
AN137 AN137SW Lithium Ion Battery Charger Using C8051F300
AN138 AN138SW Power Management Techniques for the 'F30x and 'F31x
AN139 AN139SW USB Firmware Programmer's Guide
AN140 AN140SW Integrating HI-TECH 8051 Tools into the Silicon Labs IDE
AN141 AN141SW SMBus Communication for the ’F30x and ’F31x
AN142 AN142SW FFT Routines for the C8051F12x Family
AN143 AN143SW Code Banking Using the Tasking 8051 Tools
AN144 AN144SW CP2101 Customization Guide
AN145 AN145SW Reference Design for the Three-Channel Power Sequencer
AN146 AN146SW Reference Design for the High-Speed Lithium Ion Battery Charger
AN147 AN147SW Reference Design for the Wireless Digital Full-Duplex Voice Transceiver
AN148 AN148SW Reference Design for the Magnetic Stripe Reader
AN184 Digital Counting Scale
AN189 AN189SW MMC Data Logger Example
AN191 AN191SW Motor Control Software Examples
AN197 AN197SW Serial Communications Guide for CP210x
AN198 AN198SW Integrating SDCC 8051 Tools Into The Silicon Labs IDE
