kannan2590
Member level 4
i have studied and understood signed additions concept when overflow will occur and not.if both numbers are negative and answer is positive then overflow will be there . but when i am imlementing fir filter in vhdl and the overflow occurs while signed addition is there any solution to detect that overflow and i want to get correct output samples without the overflow problem. is there any permanent solution or code in vhdl. so that i can get correct output sample considering the overflow bit . is there any need to write code for overflow detection while addition along with fir filter code in vhdl.
