sarmad88
Junior Member level 2
- Joined
- Feb 12, 2013
- Messages
- 20
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,474
hi
my design is use fixed_pkg to find the mean value for two array (a and b) each 16 input
and when synthesize the deign the warning below produced
Xst:1781 - Signal <a> is used but never assigned. Tied to default value.
Xst:1781 - Signal <b> is used but never assigned. Tied to default value.
the code is below :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use std.textio.all;
use work.fixed_pkg.all;
--library UNISIM;
--use UNISIM.VComponents.all;
entity operations is
Port ( clk : in STD_LOGIC;
selector:in std_logic;
mean_resultut std_logic_vector(16 downto 0));
end operations;
architecture Behavioral of operations is
type ram is array(0 to 15) of sfixed(4 downto -8);
--ex1
--A=[3.1 -1.6 1.12 -0.19 -10.111 0.4 2.2 -5.6 -12.7 3.8 4.66 -1.222 10.61 0.99 -1.31 9.87]
signal a:ram:=(
"0001100011010","1111001100110","0000100011111","1111100010111",
"1010111100100","0000001100110","0001000110011","1101001100110",
"1001101001101","0001111001101","0010010101001","1111011000111",
"0101010011100","0000011111101","1111010110001","0100111011111"
----B=[2.3 1.9 -1.1 -0.81 0.78 0.515 0.629 -3.23 11.6 -15.313 -2.9 0.1 -0.09 0.13 8.9 4.2]
signal b:ram:=(
"0001001001101","0000111100110","1111011100110","1111100110001",
"0000011001000","0000010000100","0000010100001","1110011000101",
"0101110011010","1000010110000","1110100011010","0000000011010",
"1111111101001","0000000100001","0100011100110","0010000110011"
signal count:integer range 0 to 16:=0;
signal accumlator_resultx,accumlator_resulty:std_logic_vector(16 downto 0);
begin
process(clk)
variable sum1:sfixed(8 downto -8);
begin
if(clk'event and clk='1') then
if(count=16)then
accumlator_resultx<=to_slv(sum1);
else
sum1:=resize(sum1+a(count),sum1);
end if;
end if;
end process;
process(clk)
variable sum2:sfixed(8 downto -8);
begin
if(count=16)then
accumlator_resulty<=to_slv(sum2);
else
sum2:=resize(sum2+b(count),sum2);
end if;
end if;
end process;
process(clk)
begin
if(count<16)then
count<=count+1;
end if;
end if;
end process;
process(selector,accumlator_resultx,accumlator_resulty)
begin
case selector is
when '0' => mean_result<=accumlator_resultx;
when others=> mean_result<=accumlator_resulty;
end case;
end process;
end Behavioral;
in the ISE14.1
please how can overcome this waring and
is this waring effect to my design when design is configure into FPGA device ???
the code is below :
library IEEE;
use std.textio.all;
--library UNISIM;
end operations;
--ex1
signal a:ram:=(
signal b:ram:=(
begin
process(clk)
begin
if(count=16)then
else
end if;
end if;
end process;
process(clk)
begin
if(count=16)then
else
end if;
end if;
end process;
process(clk)
begin
if(count<16)then
count<=count+1;
end if;
end if;
end process;
begin
case selector is
end case;
end process;
end Behavioral;
in the ISE14.1
