Signal integrity issues with dynamic logic nets on normal nets
snr_vlsi
Member level 1
Consider this scenario.
Consider an inverter with an input net and an output net connected it. There is a neighbouring net which is actually a floating net and there is no transition on this net.
What is the effect of this floating net in terms of signal integrity on the nets connected to inverter where there is a transition from low to high.
Does any one have any idea about signal integrity issues with dynamic logic nets on normal nets
i.e. dynamic logic nets are nets connected to logic gates that are precharged and does not transition.
thx
snr_vlsi
navdeep_77
Newbie level 1
Signal Integrity
If this is static floating net then this cannot cause crosstalk delay/glitch on other nets. However, if there is an aggressor transitioning nearby, it may cause a glitch on this net.
ljxpjpjljx
Advanced Member level 3
Shang Hai
Re: Signal Integrity
so you should make an analysis on this case whether cross talk and noise glitch will have impact in realtime!
natg9
Member level 3
i think Navdeep is right
it will not have any effect but usually we tie it to ground as a precautionary measure
no net left ids left floating
