signal change in VHDL
alexz
Full Member level 5
UK
vhdl detect signal change
How to detect a std_logic_vector change?
I see I can not use the " 'change " attribute because it is not synthesizable.
vhdl signal change
what you can do is, delay the signal by 1 clock cycle and then perform XOR with delayed signal
let us assume that y be your std_logic_vector and f1_y be the delayed signal
detect_change <= f1_y XOR y;
whenever there is a change in y, there will be a pulse on detect_change
hope this will help...
signal change vhdl
How will I make the delay?
process changing vhdl
here is a sample code...
PROCESS(clk, rst)
BEGIN
IF (rst = '1') THEN
f1_y <= (OTHERS => '0');
ELSIF (clk'EVENT AND clk = '1') THEN
f1_y <= y;
END IF;
END PROCESS;
f1_y is delayed signal of y
vhdl delayed version of a signal
So, then I have to check weather f1_y = y in a different process right?
signal change vhdl
no you don't need to place it in a different process, which will make another clock cycle delay...
you can do this outside the process
vhdl change
put another process in ur programme like
process(anai)
c <= a and anai;
end process;
where anai is the logic vector u defined..and choose " a <= '1' "..observe c at the out put...
