nakshathra
Junior Member level 1
the below code shows up this error when i try to synthesize it.. can sumone please sort out!
ERROR:Xst:827 - "C:/Documents and Settings/Administrator/Desktop/xilinx prgms/tr/tr.vhd" line 64: Signal count cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release.
entity port:-
y as output std_logic_vector(3 downto 0)
em as input std_logic_vector(3 downto 0)
clkout as input
_____________________________________________________________________________________________________________________
architecture signals:-
signal y_temp:std_logic_vector(3 downto 0):= "0000";
type st is (s0,s1,s2,s3,emergency);
signal state:st;
signal temp_out,clkout: std_logic := '0';
______________________________________________________________________________________________________________________
process(clkout,em)
variable count,count_em: integer := 0;
variable temp: std_logic_vector(3 downto 0);
variable pr_st: st;
begin
case state is
when s0 => if(em /= "0000") then temp:=y_temp; y_temp<=em; pr_st := state; state<= emergency; else
if(clkout ='1' and clkout' event) then
if(count<4) then y_temp<= "0001"; count:= count + 1;
else state<= s1; count:= 0; end if;
else null; end if; end if;
when s1 => if(em /= "0000") then temp:=y_temp; y_temp<=em; pr_st := state; state<= emergency; else
if(count<4) then y_temp<= "0010"; count:= count + 1;
else state<= s2; count:= 0; end if; else null; end if; end if;
when s2 => if(em /= "0000") then temp:=y_temp; y_temp<=em; pr_st := state; state<= emergency; else
if(count<4) then y_temp<= "0100"; count:= count + 1;
else state<= s3; count:= 0; end if; else null; end if; end if;
when s3 => if(em /= "0000") then temp:=y_temp; y_temp<=em; pr_st := state; state<= emergency; else
if(count<4) then y_temp<= "1000"; count:= count + 1;
else state<= s0; count:= 0; end if;else null; end if; end if;
when emergency => if(clkout ='1' and clkout' event) then
if (count_em < 10) then
count_em:=count_em+1;
else
y_temp<=temp;
state<= pr_st;
count:=count + 3;
count_em:=0;
end if; else null ;end if;
end case;
end process;
entity port:-
clkout as input
signal state:st;
process(clkout,em)
variable pr_st: st;
begin
case state is
else
y_temp<=temp;
state<= pr_st;
count:=count + 3;
count_em:=0;
end case;
end process;
