Register Log in
Signal and Variable ....in VERILOG
Guru59
Full Member level 4
hai.
i am NOVICE in verilog.i need to know how to declare SIGNAL and VARIABLE in Verilog...
thanks in advance
aji_vlsi
Advanced Member level 2
Bangalore, India
Guru59 said:
hai.
thanks in advance
Guess you come from VHDL background, in Verilog just use "reg" datatype and use blocking and non-blocking assignment. Roughly a variable is like a reg with blocking assign and SIGNAL behavior is mimiced using reg and non-blocking.
Do a quick google search, there are tons of Verilog material available in the net. If you require a jump start, hands-on training in Verilog, send an email to cvc.training@gmail.com
Good Luck
Ajeetha, CVC
www.noveldv.com
SkyHigh
Advanced Member level 1
hi guru59,
In Verilog, whether the choice is a signal or variable will depend on:
(1) wire or reg is used
(2) always or assign is used
For example, a variable would look like this:
reg Y;
always Y <=1;
//This is called Non Blocking Procedural Assignment Statement.
//But it is only possible inside an Initial statement.
//Likewise, it is a variable can only be used inside a Process statement.
For example, a signal would look like this:
wire n;
assign n=1; //Note that wire is only used for in or inout. Never for output because wire is for reading, not latched or registered for output.
Alternatively,
reg Y;
always @(posedge clock) Y=1;
//In this case, reg is output signal which is registered or latched.
Guru59
Full Member level 4
Thanks for that aji and Skyhigh........
does anyone of you can upload any material regarding blocking and non-blocking statements.............
anishrai
Member level 1
Search for the book " verilog HDL...a guide to digital design and synthesis" by samir palnitkar......its a good book...
Toggle Sidebar
