sigma-delta modulation problem
mustangyhz
Member level 5
module modulator(clk, rst, k_in, v_out, v_out_offset);
input clk, rst;
input [23:0] k_in;
output [3:0] v_out, v_out_offset;
reg [3:0] v_out,v_out_offset;
reg [23:0] D1, D2, D3;
wire [23:0] sum1, sum2, sum3, sum4, sum5, sum6, sum7, v_fd, v_fd_neg;
assign sum1 = k_in + v_fd_neg;
assign sum2=sum1 + D1;
assign sum3=D1 + D2;
assign sum4=D2 + D3;
assign sum5=D2 + {D2[23],D2[23:1]};
assign sum6={D1[22:0],D1[0]} + {D3[23],D3[23:1]} +sum5;
assign sum7=sum6[23:19] + 1'b1;
always@(posedge clk or posedge rst)
begin
if(rst) D1<=24'h0;
else D1<=sum2;
end
begin
if(rst) D2<=24'h0;
else D2<=sum3;
end
begin
if(rst) D3<=24'h0;
else D3<=sum4;
end
begin
if(rst)
begin
v_out<=4'b0000;
v_out_offset<=4'b1000;
end
else
begin
v_out<=sum7[4:1];
v_out_offset<=sum7[4:1]+ 4'b1000;
end
end
assign v_fd=~sum7[4:1]+1'b1;
assign v_fd_neg={v_fd[3:0],20'h00000};
endmodule
I don't know what these code means:
question:4 bits for v_out, 5bits for sum7? what does "1'b1" mean?
what does "4'b1000" mean?
// modulator testbench
//`include "errorfeedback.v"
//'include "../../rtl/modulator.v"
module test;
reg clk;
reg rst;
reg [23:0] k_dth;
reg [31:0] bout_sum, clk_sum, averange;
wire [3:0] bout, bout1;
modulator M1(clk, rst, k_dth, bout1, bout);
always #2 clk = ~clk;
initial
begin
bout_sum = 25'b0;
clk_sum = 25'b0;
averange = 25'b0;
clk = 1'b0;
k_dth = 24'b0;
rst = 1'b1;
#100000 k_dth = 24'b000000100000000000000000;rst=1'b1;
#1 rst=1'b0;
#100000 k_dth = 24'b000001000000000000000000;rst=1'b1;
#1 rst=1'b0;
#100000 k_dth = 24'b000010000000000000000000;rst=1'b1;
#1 rst=1'b0;
#100000 k_dth = 24'b000010000000001000000000;rst=1'b1;
#1 rst=1'b0;
#100000 k_dth = 24'b000100000000000000000000;rst=1'b1;
#1 rst=1'b0;
#100000 k_dth = 24'b001000000000000000000000;rst=1'b1;
#1 rst=1'b0;
#100000 $stop;
end
begin
if (rst)
begin
bout_sum = 25'b0;
clk_sum = 25'b0;
averange = 25'b0;
end
else
begin
bout_sum = bout_sum + bout - 8;
clk_sum = clk_sum + 1;
averange = {bout_sum,20'b0}/clk_sum;
end
end
endmodule
4'b1000 - the word length is 4; 1000 - the binary value
sum7=sum6[23:19] + 1'b1 - one have to be added to 4 msb from sum6
for example sum6[23:19]=1001 then sum7=1001+1 = 1010
Did you notice that the coefficients in the code are different from those in the signalflow diagram?
thank you!
the coefficients in the code have been edited.
---------- Post added at 01:45 ---------- Previous post was at 01:41 ----------
tupadupa:
thank you!
I know 4'b1000 - the word length is 4, question is why the word length of sum7 is 5(sum7=sum6[23:19] + 1'b1)? why dose one has to be added to sum6? and why dose 4'b1000 has to be added to sum7?
I think, it's intended as rounding applied before the 4-Bit quantizer
Check the usage and specified number format of the output signal v_out_offset to answer the question. Seems like the signed representation of v_out is converted to offset binary.
The right forum for your question would be Digital Signal Procesing rather than Microwave, by the way.
"A 1.1-GHz CMOS Fractional-N Frequency Synthesizer with a 3-b Third-Order SDM":
one added to sum6 is used for dithering.
"CMOS Fractional-N Synthesizers Design for High Spectral Purity and Monolithic Integration"
4'b1000 added to sum7 is to avoide the unstable input regions.
None of both explanations is obvious from the shown code, they don't even sound plausible in my ears. Dithering e.g. involves a pseudo random source, that isn't present as far as I see. But it's good, if you could find the answer yourself.
I don't have access to the quoted IEEE publication, so I can't check it myself. Do I understand right, that it's also the source of the Verilog code?
mustangyhz:
sorry, I didnt read your question carefully. Now I got the problem.
the code:
v_out<=sum7[4:1];
corresponds to the quantizer in the matlab model of dsm.
why then 4b'1000 was added I dont know. Simulations should help.
I played only with matlab model of dsm. In a case when data type of the signals changed to signed integer, the quantizer can be removed.
