siwarex ms
Hello
I used 2 siwarex MS modules with a CPU 226 ,and used default setting of it, and used its library to read it from S7-200 CPU226 (like the example given in the siemens examples and documents).
RUN led of module (LED2) is continuously ON for several hours ,it means it works properly,everything is good ,but some times suddenly (after several houre of good operation) one of the modules does not operate properly and RUN led flashes rapidly on/off! It means CPU does not scan SIWAREX?!!
Where can I find SIWAREX softwares tools free?
what is the problem ? what can I do?
My program have no bug and works OK for several hours.Another module is working good,only one crashes to operate(I must restart system again)
