Most programming of Siemens S5 PLC's is done using a special RS232 to TTY converter. The S7 series are programmed using a RS232 to MPI bus converter. The easiest thing to do is buy these special cables from your local Siemens supplier. The operator terminals however can be programmed using a normal serial cable. The following cable can be used to program the OP series of operator displays. https://www.automationdirect.com/static/manuals/eztouchm/appxa.pdf
