i am attaching a vb screen shot which shows the temperature and humidity taken as 14 bit and 12 bit respectively. It also shows the communication between the microcontroller and sht10. The info is passed to pc thru serial communication. Each line is one full set of communication.
R stands for com reset.
s stands for transmission start
s-f is softreset command
s-u is status write command
u-w is data written into status reg
s-v is status read command
v-x is status reg data read - which is different from what i wrote into it problem no. 1
x-z is checksum
s-t is temperature measurement command
t-j is msb of temp
j-k is lsb of temp
k-r is checksum
s-h is humidity command
h-y is msb of humidity
y-next eight bits is lsb of humidity
temperature count is shown top box next to humidity text box
humidity count is shown in top right box
the air temperature and humidity was 26.5 and 55%
the sht10 was manually soldered and no recharge time was given. will the humidity and temperature come back to the actual value after a day or is there some problem in the communication
Cannot help with all your VB code but as the datasheet says you should allow time for the sensor to recover after soldering - although I did not notice any great problem.
Unless you have a known good humidity sensor to work against perhaps you should do a salt box calibration on the SHT10 - see this pdf for details for how to do this -
with common house salt you should get 75% at 20 -25 deg C - ensure you do just moisten the salt and not turn it into a runny mess.
Does the temperature reading also get affected by soldering?
any source code for communication with sensor?
what is the slowest clock that can be applied to sck?
I got the problem solved. i just needed to pulse before i read the data pin. i was reading after clocking it. so the data moved a bit left increasing the count. I made a temp oscilloscope monitoring from the laptop. and i found what was the mistake.
thanks all of u who replied
