Show me how can I realize amba?
zwj_seu
Member level 2
amba ahb generator
Hi ..
everyone!
Who can help me to realize amba,or give me some advice?
zwj_seu
jamesyang1209
Full Member level 1
Re: How can I realize amba?
My experence:
Our company bought some IP inlucde AMBA interface, then we coding AHB arbiter and decoder by ourself. When we encounter some problem, we will go back to check the IP's testbench timing waveform. Other IPs (no AMBA interface) were packeage into AMBA IF by ourself.
wadaye
Full Member level 4
Hi zwj_seu:
Suppose you mean AMBA2.0.
You need Master , Slave, Arbiter, Decoder, S2M, DMA_Controller,
Interrupter_Controller, MUX, AHB2APB, Master, Slave to constitued a
AHB bus. And AHB2APB Bridge plus some APB_Slave will constitute the
APB bus. You can find detail description in the SPEC.
The most important is ARBITER. You need to determine the arbiter
strategy first before you design.
wang1
jamesyang1209
Full Member level 1
You can told us more about your project or your plan.
Are you just learnig AMBA in school or doing a project in a company?
zwj_seu
Member level 2
The system has four ahbmodules:core,dma,lcdc,emi,mma.
I was told to implement amba bus using verilog.
I want to know how to implement ahb arbiter.
From the amba spec, I just learn arbiter's behavior.
I do not know arbiter's inner implement.
eda_wiz
Advanced Member level 2
In AHB arbiter most important thing is the arbitration alogorithm...First you ahve to decide on that ....
May be as a start you can implement a simple priority algorithm.. In which a higher prority master when requests the bus the arbiter immediately give the bus control...
the arbiter interface will be having some inputs pins for bus requests.. and some output pins for bus grant..
You better give a try with this .. and please ask specidic questions...
regards
whizzzzkid
eeeraghu
Full Member level 4
yes AHB Arbiter is the most imp part in the bus, but implementing Bus master interface and slave interface is not a simple thing.
C4Cheema
Member level 3
Spain
Can someone help me (how to get AMBA 2 Bus System?)
That defines bus hierarchy of a system bus and a peripheral bus
I want to link two IPs which are AHB 2 Compliant.
Best Regards
