grizedale
Advanced Member level 3
Hello,
Why is it that i cannot find a white 500mA or 700mA rated white LED that's cheaper then the 1A rated XPEWHT LED from Cree?
-Surely, lower current LEDs should be cheaper than higher current LEDs?
...but after searching on digikey, this is not the case.
-The below shows the XPEWHT LED , and the nearest priced LED to it, which is still more expensive, in spite of its significantly lower current rating.
Surely there must be a 500mA to 750mA LED somewhere in the world thats cheaper than the XPEWHT LED?
This 1 Amp XPEWHT LED is $1.03 on digikey for 5000 pieces:-
This Sheun LED is 750mA and $1.42 FOR 5000 PIECES ON DIGIKEY:-
