Register Log in
Shorted hole in SAP (Shorted Annular Patch) using HFSS
Cridav.martin
Newbie level 3
can anyone please help me designing a microstrip patch antenna in HFSS.
I have troubles creating the shorted ring, how should i do so that the patch and the ground are shorted using a hole with a huge radius?
thank you
moh.haroun
you should make a cylinder that is equl to the distance between the ground and patch in length.subtract the cylinder from the patch, ground and substrate. Then you should make an object from surface . In this way you will have a surface hollow cylinder. Use thicken sheet to add thickness to the metallic via.
Regards
Cridav.martin
Newbie level 3
what kind of boundary should I apply?, I´ve substracted the cylinder from all the layers, after that I selected the hollow cylinder with "select surface", after that "modeler->surface->create object from face", and finally I made that face with "Perfect E Boundary", is that correct? or should I give it another property so that it acts as a shorted hole like made it "pec "?
thank u so much
moh.haroun
yes this is enough. you may also add thickness to the cylinder using thicken sheet
Cridav.martin
Newbie level 3
but, if i decided to add thickness, what material should i use?
